| It will keep running if i keep on the throttle. Can't imagine it's a vac leak, I fully checked the vac lines and they're all in place, and I have replaced 99% of the lines within the last 5k I can't check fuel pressure while the car is running...because i can't keep it running. I'll try removing the vac line to the regulator, what exactly is that going to prove?
